Looking for help writing formula for pay earned based on variable
I’m looking for help writing a formula to show what pay a staff member has earned based on a variable.
I have hours worked (at 30 per hour for one role, and 25 for a different role), and trainings complete at 50 per session.
How do I write a formula that looks at the “role assigned select field” and calculates based on the correct rate of pay?
Thanks,
Best answer by JonathanBowen
Hi @Ryan_Anderson1 - you can do something like this:
IF({Role Field} = 'Role 1', {Hours field} * 30, {Hours field * 25})
and then to include the trainings you can extend this with:
IF({Role Field} = 'Role 1', {Hours field} * 30, {Hours field * 25}) + {trainings complete field} * 50
For 2 roles, an IF statement is fine. If you end up with more than this, you can move to SWITCH statement, which is often easier than multiple nested IFs
JonathanBowen
Thank you! I’ll start there and see if I have any issues, thank you!
JonathanBowen
This isn’t correct - should be:
{Hours field} * 25
