Hello everyone,
I'm fairly new to Airtable and I've been impressed with the level of questions the community has solved. This is the first time I'm posting a question with the hope someone can help me. Here is my situation:
In Table A, I have 3 single-select fields called Trade Choice 1, Trade Choice 2 and Trade Choice 3. Each record (applicant) has a Province of Residence. I have a lookup field to Table B that lists each trade with the specific provinces where the trade is a Red Seal trade in a multiple-select field called Red Seal Province.
I want to add a verification step to confirm when the choices of jobs are entered that they are a Red Seal Trade in the province of residence of the applicant. I would ultimately use condition colour to highlight any choices where the trades don't exist as a Red Seal in the province of residence.
How do I write an IF formula that would say: IF(Red Seal Provinces from Trade Choice 1, Trade Choice 2 and Trade Choice 3 has any of the Province of Residence, then return "yes", otherwise return "no")
Could anyone help with a formula that would mean has any of below or suggest a better way to go about this? Thank you for your expertise, time and dedication to the Airtable community.
IF({Red Seal Provinces Trade Choice 1} has any of {Province of Residence}, "yes",
OR(IF({Red Seal Provinces Trade Choice 2} has any of {Province of Residence}, "yes"),
OR(IF({Red Seal Provinces Trade Choice 3} has any of {Province of Residence}, "yes", "no" ))
