Removing NaN where + and - values can exist
  • February 25, 2025
  • 89 views
Hi there! I am trying to remove NaN values from a formula field where both positive and negative values exist. This is in an effort to clean up two extensions: One chart indicating the number of each value's occurrence and one number where I am trying to get the average of the values, but with NaNs included I receive an infinity.
Here is my current formula:
DATETIME_DIFF(
{Due Date},
{Date Completed},
'days'
IF({Date Completed},{Due Date} = "NaN", BLANK())
Thank you in advance!
Best answer by Marvel
It looks like your formula has an issue causing NaN values. To fix this, you can update your formula to make sure it only calculates when both dates exist. Try this:
IF(AND({Due Date}, {Date Completed}), DATETIME_DIFF({Due Date}, {Date Completed}, 'days') )
This will prevent NaN values and keep your charts and averages clean. If you need more help, feel free to ask! 😊
  • February 25, 2025
  • February 26, 2025
This worked beautifully! Thank you very much 🙂
