Simple way to highlight duplicate entry
@ScottWorld , I went through a few options to look at ways to just highlight the duplicate entries as they get entered into a database. I noted u came up with a simple one but there were no steps written down.
We have a unique patient ID which is in the primary column , we dont want to duplicate a patient file. Every time we enter we wish to have a look and see if there is a duplicate entry and delete if its highlighted. makes sense?
Forum|alt.badge.img+33
  • 8768 replies
  • July 21, 2021
That is not possible with Airtable’s native capabilities. You can search for duplicates after the fact with Airtable’s DeDupe app:
@ScottWorld thank you.
Hope we get s solution in the future. :slightly_smiling_face:
  • April 12, 2024
Agreed!  We need to see if something is going to be duplicate when it's entered into the database / table immediately!  Highlighting or something would be key!
  • December 11, 2024
Agree, I also need this feature, where duplicate rows are highlighted on adding to a database. Hope we get this in the future.
