Adding Groups to a blank Interface
Is it possible to add groups to combine elements when starting from a blank interface?  I have groups when starting from a dashboard, but I’d like to be able to add them to a blank interface.
mtrebinonixon
The Blank interface layout does not support adding a "Group" section like the Dashboard layout does. While you can manually structure elements using grids, lists, text headers, and layout components to mimic grouping, there isn’t a built-in way to group sections natively.
Additionally, Blank pages are not supported on mobile, so if mobile accessibility is important, I would suggest to consider using a Dashboard or another structured layout instead.
Could you share more details on what you're trying to achieve?
Hey ​@AristoTim!
As ​@mtrebinonixon mentioned, that is not possible. What exactly are you using Blank layout for, and what pros do you find in it vs. other layouts? Interested to see we can find any other page work better for you.
Blank pages are not ideal (although they are the best option for some very specific use cases).
Best,
