Interface Checklist Unclickable
I have the below interface
The idea is to give the service team members a touchable sheet they can use a tablet to checkoff when putting a cart together. However, the checklist is not editable inside of the interface which seems really stupid to not be able to do, plus for whatever reason isn't even viewable inside of a tablet/phone so defeats the purpose entirely. Any ideas?
Best answer by Joseph_Roza
 After you select the Update Record automation step, this is where you select to update from a Template.
Forum|alt.badge.img+33
  • 8774 replies
  • March 18, 2024
You make it editable in the right margin.
  • 17 replies
  • March 18, 2024
The text fields aren't editable unfortunately /:
  • 8774 replies
  • March 18, 2024
Did you just type that text on the interface? If you just type text on an interface, that is not editable. Typed text is for you to provide headers or instructions. Only fields can be edited in Airtable.
  • 17 replies
  • March 18, 2024
Right, but theres not another way to get a clickable checklist in Airtable interfaces that I'm aware of outside of creating a field for every single item
Joseph_Roza
  • 66 replies
  • March 18, 2024
I believe on the dashboard interface view, list items are not able to be edited at all. I don't know if they plan on changing this in the future, but for now, it's a limitation of the new dashboards.
Joseph_Roza
  • 66 replies
  • March 18, 2024
Apologies for not looking more in-depth to your issue. I think, in your case, it's best to create a checklist of records using the list view, rather than using the deprecated checklist text type on the interfaces. I kind of wish they would remove that option, as it's a bit counterintuitive. You would then have an editable, clickable checklist.
  • 17 replies
  • March 18, 2024
Was actually easier to do this than I thought it would be. What would you recommend to make this accessible from mobile or tablet? Kinda defeats the whole purpose of an interface
Joseph_Roza
  • 66 replies
  • March 18, 2024
Use the dedicated list view interface page, then ensure allow users to edit/add/remove records inline is toggled on. This will be mobile optimized and editable.
  • 17 replies
  • March 20, 2024
The problem with this here, is that each record needs a fresh list of boxes to check, otherwise, if they follow the SOP checklist for lead A, then they would have to manually unclick everything then refollow the checklist for lead B
Joseph_Roza
  • 66 replies
  • March 20, 2024
This is where record templates come into play: https://support.airtable.com/docs/using-record-templates-in-airtable
For instance, create another table called 'Projects'. Link it to your tasks table. Then create a template for the Projects table with however many repeatable tasks (child records, as they're referred to in record templates) you need it in. Now, in the interface, you'll be able to create a new 'project' based on a template, and all those repeatable tasks will be created in the tasks table, without having to uncheck and recheck each item.
  • 17 replies
  • March 20, 2024
I think we're almost there. Thank you for the help. So we have our main table, pipeline, which is our sales pipe line, broken down by views. So once a customer has placed their deposit, they move into the preparing for delivery view. On another table, checklists &  SOPs, is where we initially housed that checklist.
So I'm assuming I would make a record template there, but then in the automation/connecting how would I make it to where every lead once in Preparing for delivery view had their own templated record from the checklists and SOPs table?
Joseph_Roza
  • 66 replies
  • March 20, 2024
Use an automation with a trigger of 'when record enters view'. The next step in the automation is 'Create record'. Select the table with the project template (which contains the list of child records task list), then for 'Create record' option of that 'Create record' automation step, select 'From a template' and select your newly created template. I hope that makes sense. Let me know if you have any questions.
  • 17 replies
  • March 21, 2024
Won't that just create duplicate leads in the pipeline?
  • 17 replies
  • March 21, 2024
And then if we made it ready for delivery inside of the interface, we would then have to go back and do it again on the original lead?
Joseph_Roza
  • 66 replies
  • March 21, 2024
Apologies. You should use 'Update Record' as opposed to 'Create Record' automation action. This will allow you to update fields of existing records, as opposed to creating new ones. I'm not sure what you mean by your second question. Can you clarify?
  • 17 replies
  • March 21, 2024
You answered it. Let me build it now and see if it works
  • 17 replies
  • March 28, 2024
Could you take a screenshot of your automation trying this. Not seeing anywhere to make a template
Joseph_Roza
  • 66 replies
  • April 5, 2024
  • 17 replies
  • April 5, 2024
 got it to work. Have a way more complex one if you want the challenge!
Joseph_Roza
  • 66 replies
  • April 5, 2024
Of course. Share the issue and I'll assist as best I can.
  • 17 replies
  • April 5, 2024
https://community.airtable.com/t5/formulas/hardest-problem-i-ve-ever-encountered/m-p/182017#M21661
