Since the latest update, when looking at our Interface the data is getting jumbled. eg. we allocate workers to projects and they are correct on our Base, however when we look on the Interface on a mobile phone the columns seem to mix up and Workers are appearing against the incorrect projects. Has anyone else experienced this or have a fix for this?
Hey
Hey
Is this still an issue? I’d be happy to hop on a 5 min call and go through it together. Feel free to grab a slot using this link.
If you believe this is a bug you might want to reach out to support@airtable.com
YouTube Channel
Thanks for the responses.  Airtable support finally got back to me and a simple “remove the app and reload” (which I thought we had already tried) seemed to have sorted the issue.  I’ll keep an eye on it and if it happens again I will definitely come back to you
Glad to hear that
Absolutely, reach out as needed :D. I’d be happy to help.
YouTube Channel
