Interface filtering missing fields
  • September 19, 2024
  • 33 views
Heyhey
I'm need a dynamic filtering option in the interface so I'm trying to use the built-in filter. For some reason the filterable fields that appear are not all the possible fields but just a random selection. I need to filter by status but status field is not an option to filter with the built in filter. See screenshots.
Anyone can help ?
Forum|alt.badge.img+28
Hmm, is the "Status" field a formula field that's formatted to output options?  Single select fields show up in both filters for me, but formula fields don't show up for the one within the interface:
Link to base
  • 13 replies
Link to base
Hey, thanks for sollowing up !
no its a single select field, but it's coming froma synced table. I wouldnt see why this would be a blocker since the fields that appear are synced fields as well, see screenshot
Interesting!  May want to open a support ticket with Airtable directly about this I reckon, seems like it's just not supported at this point
