Interface Layout
CHEschool
How do you accomplish that Airtable shows as the example?  I want a picture on one side, then next it it several vertical fields, but they only go horizontally or below the picture.
DisraeliGears01
It took just a minute of drag/dropping playtesting, but I was able to recreate this format in a record review. You’re right that initially the fields wanted to stack horizontally rather than on top of one another, but basically when you create columns of fields next to the image, you can add more fields to the column created, creating the vertical field stacking effect.
This is really hard to describe textually haha.
DisraeliGears01
Here’s a Loom, easier than describing the process. Took me two or three tries till I consistently figured out the drag/drop processes for replicating this exactly.
  • March 19, 2025
Perfect!  Thanks I got it!
