Looking for Assistance: Help Building a Drag-and-Drop Booking Timeline in Airtable
  • August 26, 2024
  • 20 views
Hi everyone!
I'm relatively new to Airtable and currently working on a final project for a company I used to work for. I introduced them to Airtable, but they want to keep the overall cost under $35 per month.
For the project, I'm trying to create a Timeline View where the first column displays all the apartments from the "Apartments" table, and the other columns represent dates. Additionally, I would like to have a list of bookings on the right-hand side that only shows bookings which haven't been fully assigned yet (those with a "Beds Remaining to Assign" field greater than zero). My goal is to be able to drag and drop these unassigned bookings onto the timeline, matching them to the appropriate apartment.
I'm hoping someone in the community might be able to guide me through building this or point me in the right direction. I’m happy to pay for assistance in getting this setup right!
Any advice or help would be greatly appreciated!
Thank you so much!
Forum|alt.badge.img+31
Hmm, if you want to do the drag and drop each "Bed" will need to be a single record I think.  You could try setting up a system where you can drag and drop the record and set the number of beds you're assigning for that apartment and having an automation create a new record with the remaining number of beds, but that seems pretty complicated
