What is the proposed idea/solution?
- New Comment automation trigger with conditional logic
 - Add actions to list, create, delete and update records
 - On a JavaScript record object, add methods to list, create, delete and update comments
How does is solve the user problems?
Automation triggered by new comments could be used at the user's discretion. One example is to send a message/notification to a third-party service like Microsoft Teams.
The ability to create comments from automations/scripting could be used at the user's discretion. One example is to leave a comment (as an automations user) if a record didn't meet certain conditions.
The current method requires:
- Generate an access token with data.recordComments:read and/or data.recordComments:write scope
 - Add a Script action to an automation
 - Craft a fetch request for each comment operation and exposing the access token
Would be much simpler to create an instance of a record object and use a method like:
record.createComment()
record.deleteComment()
record.updateComment()
record.listComments()
Who is the target audience?
All users
