Default Single Select
  • July 29, 2019
  • 6 replies
  • 46 views
Ability to have a default value for single select - would be perfect for forms filled by applicants in our HR process.
  • August 9, 2019
I’m seconding this request! I have a task management dashboard and would like that the state of the task is “Inbox”, and not have to type it every time I enter a task.
  • February 27, 2020
Also requesting this.
In terms of a use case, we have records for requests that are submitted by form, with a grouped view based on a single select status option that can be changed depending on where the request is in the process of being dealt with.
Being able to have a default value input on a single select item would allow newly submitted request records to be categorised more effectively, and allow filtering/grouping in views slightly more intuitively for users.
At the moment, records are categorised by an ‘empty’ status at first receipt, which causes a couple of headaches in terms of user interaction. Having a status already input encourages users to modify the status single select field - when it is empty it is more prone to being left empty, leading to inaccurate information.
:thumbs_up:
  • March 11, 2020
+1
I am using AT to manage our ordering system. Any record should start with the same status field and it will be great to have it filled automatically to a default value
  • September 9, 2020
Please add this feature.
+1 for this suggestion
  • January 4, 2023
+1
