Feature Request: Add totals to chart blocks
It would be great if there was an option to add totals to the various chart blocks. This can be useful for reporting. Please see the attached example:
Forum|alt.badge.img+33
  • 8814 replies
  • June 5, 2020
I totally agree that this is a needed feature! I’m not at a computer right now so I can’t test this, but if you hover over the chart with your mouse, does it at least show you the totals while you’re hovering?
It shows you the total for each section on hover - which does help!
  • 8814 replies
  • June 5, 2020
Wow, nice! We’re halfway there! :slightly_smiling_face:
