In-Cell Progress Bar for Each Record
Hi -
We’re looking to pull a percentage of a task complete and reflected that % as a progress bar in a cell for a single record. We want the progress bar to be continuous (up to an integer) as the % of the task completed is updated… I.e. (just one of many use cases) if we have a record that is counting # of forms submitted for a given record, and the total number is noted in the record, the percentage of completed forms with respect to the completed record is reflected in an updating graphic progress bar.
Bootstrap plugin example: https://www.w3schools.com/bootstrap/bootstrap_progressbars.asp.
The progress bar Airtable feature should update from as the percentage cell on the record self-updates upon completion of a given trigger elsewhere in the Airtable ecosystem.
Many thanks!
  • 1386 replies
  • February 27, 2018
In the meantime, here is a status bar you can drop into any [knock wood] base as needed.
As configured, it requires you to add three Formula fields, {BarGoal}, {BarCurrent}, and {StatusBar}.
  1. {BarGoal} should be set to equal the ABS() value of whichever Airtable field contains your target goal.
  2. Assuming {Current} is the field containing your current measurement, {BarCurrent} should be set to
    IF({Current},ABS({Current}),0)
  3. {StatusBar} should be configured for the following formula:
    BarGoal,
    REPT(
        INT(
            (IF(
                BarCurrent<=BarGoal,
                BarCurrent,
                BarGoal
                )/BarGoal)*18
            ROUND(
                MOD(
                    (IF(
                        BarCurrent,
                        BarGoal
                        )/BarGoal)*18,
                    1
                0
                )=1,
As provided, the status bar is 18 characters wide at 100%; this width can be varied by replacing the value ‘18’ with your preferred width. The status bar maxes out at 100%, and blank values of {BarCurrent} are treated as zero (0). The formulas for {BarGoal} and {BarCurrent} take the absolute values of your goal and current metrics to avoid generating errors, but negative target or current values probably won’t work the way you expect.
Optionally, the status bar can be preceded with the current percent of goal reached by using the following formula:
    BarGoal,
    REPT(
        3-LEN(
            INT(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*100
        INT(
           (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
        REPT(
            INT(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*18
                ROUND(
                    MOD(
                        (IF(
                            BarCurrent,
                            BarGoal
                            )/BarGoal)*18,
                        1
                    0
                    )=1,
  • March 1, 2018
    BarGoal,
    REPT(
        INT(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*18
            ROUND(
                MOD(
                    (IF(
                        BarCurrent,
                        BarGoal
                        )/BarGoal)*18,
                    1
                0
                )=1,
    BarGoal,
    REPT(
        3-LEN(
            INT(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*100
        INT(
           (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
        REPT(
            INT(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*18
                ROUND(
                    MOD(
                        (IF(
                            BarCurrent,
                            BarGoal
                            )/BarGoal)*18,
                        1
                    0
                    )=1,
Thanks so much! I really appreciate this response.
This is fantastic. Thank you for this great solution, W_Vann_Hall!
Forum|alt.badge.img+8
  • 8 replies
  • October 28, 2018
I can believe I am not the only person in the world named Max Goldberg but it is blowing my mind that I am not the only Max Goldberg who wanted to know how to make a progress bar in Airtable.
Replace the ’ █ ’ with ’ ░ ’ or ’ ▒ ’ or ’ ▓ ’ for various shades other then black.
Edited the (genius) formula from @W_Vann_Hall to show the rest of the status bar shaded in grey.
Looks like this:
    BarGoal,
    REPT(
        3-LEN(
            INT(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*100
        INT(
           (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
        REPT(
            ROUND(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*10
        REPT(
            ROUND(
                10-(IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal*10),0
  • September 30, 2020
Many thanks to @W_Vann_Hall and @Sara_Guirgis for your genius and sharing skills!
Really smart solution! I tried to simplify it a bit further, since there was quite a bit of repetitive code in the progress bar. I decided to make a second column Percentage that calculated the percent value to be used for the view.
I also had to do some tweaks on the characters used since they didn’t have the same width in my chrome browser on Mac and moved the number after the bar since it seems like airtable now trims spaces, so it was hard to get the bars to align correctly with the above code sample.
Also fixed a bug where it would sometimes render 11 boxes total because of where the ROUND method was located on the empty boxes loop.
Here’s my contribution:
    Percentage >= 0,
    REPT(
        ROUND( MIN(Percentage, 1) * 10 )
    REPT(
        10 - ROUND( MIN(Percentage, 1) * 10)
    INT( MIN(Percentage, 1) * 100 )
Looks like this:
    BarGoal,
    REPT(
        3-LEN(
            INT(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*100
        INT(
           (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
        REPT(
            ROUND(
                (IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal)*10
        REPT(
            ROUND(
                10-(IF(
                    BarCurrent,
                    BarGoal
                    )/BarGoal*10),0
This may be a super silly question… however, where are you getting these rectangle emoji shapes? I only have squares in my default emojis and would love to use a color other than black. :slightly_smiling_face:
This progress bar is AMAZING! Thank you
Forum|alt.badge.img+33
  • 8795 replies
  • March 28, 2021
How is that little black/red/grey box symbol created?
I can copy & paste it from this thread, but I’m not sure how to generate it on my own.
I tried going into my emojis and choosing a black/red/grey emoji box, but multiple emoji boxes in a row don’t connect to each other (they leave a little space in between each of them).
However, the black/red/grey boxes in this thread actually DO connect to each other when you have multiple of them in a row!
Anybody know how to recreate those boxes from scratch?
    Percentage >= 0,
    REPT(
    REPT(
Dude this is awesome, is a lot simpler and worked for me! Is there a way we can change the bar colors?
  • April 9, 2021
This is an amazing Thread, and thanks for providing such a great formula. I tweaked it a bit to ensure the spacing stays aligned when the Percentage # in front of the Progress bar has 1,2, or 3 digit pad.
So you have this vs
IF(LEN(INT(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
            )&'')=1,INT(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
    REPT(
        ROUND(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*10
    REPT(
        ROUND(
            10-(IF(
                BarCurrent,
                BarGoal
                )/BarGoal*10),0
        ),IF(LEN(INT(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
            )&'')=2,INT(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
    REPT(
        ROUND(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*10
    REPT(
        ROUND(
            10-(IF(
                BarCurrent,
                BarGoal
                )/BarGoal*10),0
        ),IF(LEN(INT(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
            )&'')=3,INT(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*100
    REPT(
        ROUND(
            (IF(
                BarCurrent,
                BarGoal
                )/BarGoal)*10
    REPT(
        ROUND(
            10-(IF(
                BarCurrent,
                BarGoal
                )/BarGoal*10),0
  • August 19, 2021
Hi @Lindsey_Bavaro and @ScottWorld ,
These ‘emojis’ are a little different in that they are like another type of text character. So like ‘a’ ‘b’ and ‘c’ are all text characters, so are ‘§○•◄►♪’. (This is over simplification but I think gets the idea across) The color is then decided by the text color you are using in whatever tool you are typing in: MS Word/Google Docs, for example.
On Windows you can use the ‘alt code’ to type the different characters using the ALT button and the number pad. See https://www.alt-codes.net/ for a list of the codes and how to type them.
Or, alternatively, you can just copy the character you want from the website and paste it wherever you want to put it - I’d recommend doing this in most cases, especially if you are not using a Windows computer :slightly_smiling_face: Also, you are able to copy and paste emoji’s directly in a lot of places as well (including Airtable text, see below). I use https://emojipedia.org to search for emojis to copy and paste.
To show that you can use any(or most) of these characters, I edited Martin_Gudmundson 's simplified progress bar code to create a progress bar with stars and circle emojis!
    Percentage >= 0,
    REPT(
    REPT(
This would display this at Percentage value 50:
⭐⭐⭐⭐⭐⚪⚪⚪⚪⚪ 50%
So you can basically substitute the stars and circles for any (or most) characters! Here’s some other examples:
●●●●●○○○○○ 50%
★★★★★⛤⛤⛤⛤⛤ 50%
✿✿✿✿✿❀❀❀❀❀ 50%
♥♥♥♥♥♡♡♡♡♡ 50%
💚💚💚💚💚🤍🤍🤍🤍🤍 50%
🟩🟩🟩🟩🟩⬜⬜⬜⬜⬜ 50%
▓▓▓▓▓░░░░░ 50%
  • August 19, 2021
    Percentage >= 0,
    REPT(
    REPT(
⭐⭐⭐⭐⭐⚪⚪⚪⚪⚪ 50%
●●●●●○○○○○ 50%
★★★★★⛤⛤⛤⛤⛤ 50%
✿✿✿✿✿❀❀❀❀❀ 50%
♥♥♥♥♥♡♡♡♡♡ 50%
💚💚💚💚💚🤍🤍🤍🤍🤍 50%
🟩🟩🟩🟩🟩⬜⬜⬜⬜⬜ 50%
▓▓▓▓▓░░░░░ 50%
Wouldn’t let me tag @Martin_Gudmundson, but wanted to make sure he got credit, so tagging him here! :slightly_smiling_face:
  • September 22, 2021
    Percentage >= 0,
    REPT(
    REPT(
⭐⭐⭐⭐⭐⚪⚪⚪⚪⚪ 50%
●●●●●○○○○○ 50%
★★★★★⛤⛤⛤⛤⛤ 50%
✿✿✿✿✿❀❀❀❀❀ 50%
♥♥♥♥♥♡♡♡♡♡ 50%
💚💚💚💚💚🤍🤍🤍🤍🤍 50%
🟩🟩🟩🟩🟩⬜⬜⬜⬜⬜ 50%
▓▓▓▓▓░░░░░ 50%
Any suggestions on how to modify the formula so that if the Percentage is between a certain range it’s ‘ :yellow_square: ’ or ‘ :red_square: ’?
  • December 22, 2021
Thank you everyone for sharing ideas and formulas. I’m agree that this is a missing feature in AirTable over competitors. I hope it will be available in a near future. In the meantime, I use single select field with automation to achieve this. It’s not perfect, but it does the job. :winking_face:
Happy holidays everyone!
  • 118 replies
  • December 23, 2021
Interesting!! Thanks for sharing
  • January 18, 2022
Hey @PR1 how did you do the single select field like that?
  • January 18, 2022
Hi @Ryan4 .
First: create the single select field
For this first step, it depends of the precision you’re looking for. For exemple, if you would like to have 1% step, you will need to create manually 100x value in a single select field. In my example, I decide to have a step of 5% (0%, 5%, 10%, …) so I created 20x value in a single select field, with the value representing the % and the color associated with. And this is the fun part because you can play around with colors to get a visual result based on your needs.
EDIT: add spaces in the value, before the number and percent sign, until you reach the correct size. For example, no space for 0%, 3 spaces for 5%, 6 spaces for 10% and so on.
Second: create the formula field
Once done, you need to create the formula field that will compute the % based on the columns/values you wish. For example, estimated time and time spent. Here it’s important that the result has the same precision and same value returned as the single select field.
Final step: create an automation rule
In this final step, you need to create an automation rule that will be triggered on formula field updates. When the value of the formula field changes, the automation rule will affect this value to the single select field.
That’s it!
NOTE: if the value returned from the formula field is not part of the single select field list, the automation rule will create a new value.
Hope this help. If you have questions, let me know.
PR1 wrote:
Hi @Ryan4 .
That’s it!
Hi there,
Looking for the copy paste (single) elements so I can add it to my base.
Thanks
Forum|alt.badge.img+9
  • 24 replies
  • July 8, 2022
Alternatively, here’s a easy one using a “Progress” field and a “Progress Bar” field:
CONCATENATE(
  REPT("█",(({Progress}*100)/5)-MOD({Progress}*100,5)/5),
  REPT("░",20-((({Progress}*100)/5)-MOD({Progress}*100,5)/5))
Each black square represents 5% progress. Gray squares show the total possible progress.
  • 24 replies
  • July 8, 2022
Here ya go!
CONCATENATE(
  CONCATENATE(
    REPT(" ",(3-LEN(CONCATENATE(ROUND({Total Task Progress}*100,0))))*2),
    CONCATENATE(ROUND({Total Task Progress}*100,0)),
  CONCATENATE(
    REPT(
      IF({Total Task Progress}<0.20,"🟥",
        IF({Total Task Progress}<0.40,"🟧",
          IF({Total Task Progress}<0.60,"🟨",
            IF({Total Task Progress}<0.80,"🟦",
              IF({Total Task Progress}<1.00,"🟩","")
    (({Total Task Progress}*100)/10)-MOD({Total Task Progress}*100,10)/10),
    REPT("⬜",10-((({Total Task Progress}*100)/10)-MOD({Total Task Progress}*100,10)/10))
  • 24 replies
  • July 11, 2022
CONCATENATE(
The benefit to having the progress percentage itself appear in its own column next to the progress bar (rather than appearing with the progress bar) is that when you have groupings and the progress percentage field is showing, you can have percent values total up across groups, which doesn’t work when it’s merely displayed with the progress bar in the same field.
  • July 25, 2022
This is an awesome formula, thanks so much! The only issue I have is that the 100% doesn’t display the pretty emoji progress bar you made. Here’s what I see:
I use a linked record for Status, then assigned each Status a % Progress score. Then I look up that % score as the Total Task Progress in your formula above.
Any suggestions as to how to get that 100% all green bar looking right? I’ll keep fiddling, but thought I’d ask anyways!
  • July 26, 2022
@gliddon in your last if statement IF statement add an additional green box where the blank is. This should allow the 100% bar to appear
IF({Calculation}<1.00,“ :green_square: ”,“ :green_square: ”)
Also, how did you get rid of the spacing between your squares?
