Permissions per Base
Allow permissioning per Base within a workspace. Right now I’d have to create a separate work space to allow my users to be editors in one base but a creator in another, which creates billing problems and duplicate charges.
Forum|alt.badge.img+33
  • 8764 replies
  • April 7, 2021
No, that’s incorrect. You can have “base collaborators” or “workspace collaborators”. It sounds like you’ve setup all your users as “workspace collaborators”. Remove them as “workspace collaborators”, and make them “base collaborators” instead.
Got it, thank you. This was not clear enough to me in the UI, but I was able to figure out the changes. Thank you!
  • 8764 replies
  • April 7, 2021
You’re welcome! Glad I could help! :slightly_smiling_face:
