"Access-Control-Allow-Origin" = "*" using POST to add new records
  • 9 replies
So I have a custom app I am using, written in swift. I am trying to add records to one of my tables. But after doing some debugging I found I was getting the error: “Access-Control-Allow-Origin” = “*”. I did some research and found out it was a CORS error. And some light research and I am not sure really how to go about fixing this.
Alexey_Gusev
Forum|alt.badge.img+23
hi,
using remotefetch instead of fetch helped me
Forum|alt.badge.img+27
  • 6001 replies
  • June 21, 2022
What platform are you using to create your custom app?
Are you using the REST API to access Airtable?
Custom apps written using the custom apps/blocks sdk are written in JavaScript/React, and scripts within Airtable are written in JavaScript, so it sounds like you are using a different platform.
  • 9 replies
  • June 22, 2022
I am using Xcode to write the app in Swift. I am using the REST API to access Airtable. I never had this issue till just recently.
  • 6001 replies
  • June 22, 2022
New issues rarely crop up without some sort of change. Has anything changed in your code or platform? Are you running the code in the same environment? What errors are you seeing?
Since you are using the REST API, I am surprised that it would be a CORS issue.
  • 9 replies
  • June 22, 2022
I was running the script on a different computer. But then I ran my script on the normal computer I still get that issue. When I run the code from the app it doesn’t work. The only thing that doesn’t work is adding records to the Database. It pulls and updates records. But it won’t add records. I am assuming its a CORS issue. The title is all the response I get back says.
