Amendment to the Extract Base Metadata Script
  • September 9, 2021
  • 32 views
Forum|alt.badge.img+11
Hi Can anyone help please?
I have just found Airtable’s own Extract Base Metadata Script which is amazing! I am using it to build a library of all data across my bases by syncing to a master base.
Have found that when it runs it amends but does not delete any fields that have been deleted.
Does anyone know how I can add this to the script as it runs?
Deleting records in the new table works and then running script but no good now as all my new added fields with reference info will go.
Thanks, Maria
