Array / join / substitute
  • December 22, 2017
  • 9 replies
  • 24 views
Forum|alt.badge.img+8
Hi All!
I am trying to build the formula to show working and non workind days of a month in one field
Rules:
  • Field musst have 31 charachters, for 31 days of the Month
  • “N” for non working days and “J” for days worked
Example:
Max worked on a project on 13th & 15th
Result should be:
NNNNNNNNNNNNJNJNNNNNNNNNNNNNNN
i have a lookup field showing the days worked, and i know this goes something like
Substitute( REPT(“N”,31), {Days worked}, “N”,“J”) but i am just stuck.
thx for any help!
  • 1386 replies
  • December 22, 2017
You biggest problem will likely be the current inability to create a generalized looping process within Airtable that can then be applied to an array of records. Instead, I suspect you will have to create a formula that explicitly addresses each of 31 days — probably a big ugly nested IF() statement — with each day’s formula checking to see if that day should be flagged as ‘N’ or ‘Y’.
I thought I had put together a day-driven demo somewhere, but it must not have been ready for prime time, as I can’t find it anywhere. However, some of the faux bar charts in my Sales CRM Dashboard take a similar approach, and this reply to another post discusses the technique in more detail. The Leads Demo base discussed in this reply may also be of some interes.
Anyway, what do you want to achieve? Maybe we could advise in other ways to do it.
Thank you so very much for wanting to help!!
it´s about generating a file for the workers health insurance.
one txt field musst contain 31 x “N” or “J”, N for non working days and “J” for worked days.
  • have a table with events & dates linked to staff table
  • have set up the rolup und lookfield to find calculate and display working hours and dates
now only thing left is finding out how to substitute the days with “J” , creating this “NNNNNNJJNNN…” field
i have this in excel worked out like this:
$E$1:$E$89 = working days
$C$1:$C$89=$C2 = lastname
$D$1:$D$89=$D2 = firstname
{=CONCAT(MID(IF(ISNUMBER(MATCH(ROW(INDIRECT(“1:31”));$E$1:$E$89*($C$1:$C$89=$C2)*($D$1:$D$89=$D2);0));REPT(“J”;31);REPT(“N”;31));ROW(INDIRECT(“1:31”));1))}
Thx!
  • 1386 replies
  • December 26, 2017
Thx!
I’m so sorry – I could have sworn I posted this before the holidays. One morning in the shower I had this great idea of using binary encoding to create a 31-bit number that would represent a month of either work or non-work. Assuming x000 0000 0000 0000 0000 0000 0000 0000 represented a month in which no days were worked, all one would have to do would be to encode each day worked as 2^(Day-1), roll up the values with a SUM() aggregation function, and then, on the other end, encode the decimal value in binary, using 'N' for 0 and 'J' for 1. Much more elegant than my original suggestion.
The encoding went like a dream — and then I spent an hour trying to figure out how to generate the binary without the ability to loop. In the end, I fell back to the old stand-by, the ugly nested IF() statement — at which point it made little sense to retain the binary encoding…
Here is a quick demonstration I tossed together. (Hmmm… maybe that’s why I didn’t post this — it doesn’t appear I actually finished the base.) In any case, as you add days worked to an individual’s record, you’ll see the extracted day+’,’ string added and the corresponding ‘N’ change to a ‘J’. Each month, you’ll have to update the [Days Worked] table to reflect the new month, and you’re going to want to build in some error checking to guard against someone being paid for working on Frbruary 31. (I also see I left the powers-of-two field, {PoT}, in there for no good reason…)
Actually, now that I look at it again,m I see this is not an ugly nested IF() statement: It is actually an ugly concatenation of IF() statements. The actual muscle behind the routine starts out something like this:
IF(FIND('01,',DayIndex)=0,'N','J')&
IF(FIND('02,',DayIndex)=0,'N','J')&
IF(FIND('03,',DayIndex)=0,'N','J')&
and continues in such a a manner until it reaches
IF(FIND('29,',DayIndex)=0,'N','J')&
IF(FIND('30,',DayIndex)=0,'N','J')&
IF(FIND('31,',DayIndex)=0,'N','J')
({DayIndex} is a roill-up of the individual day-or-the-month values with an aggregation function of ARRAYJOIN(values)&','. The trailing &',' in the function — which is valid — is to guarantee a match on the last value in the rolled-up array.) (Actually, I just modified it, because it bugged me to see a single comma as the result when no days worked had been entered. The new aggregation function is
IF(COUNTA(DaysWorked)>0,ARRAYJOIN(values)&',',BLANK())
which, amazingly enough, also appears to be valid.)
Again, not a very pretty answer, but one that works!
First of all,
@Elias_Gomez_Sainz
@W_Vann_Hall
THANK YOU!
Second, i think i found a very interesting problem, not unsolvable, just i dont see it :slightly_smiling_face:
I am building a simple Project / Staffing / Timetracking base. Easy!
Now, if i include a payroll to it, it gets interesting.
Here is a preview:
Rules:
  1. you must have time tracking for every one! per project! per day! per shift!
  2. you must be able to export the data on a daily basis, (some guys work today -> csv export -> import somewhere else, finished)
  3. you mujst have MONTHLY sumarry per person to do a payroll
  4. this has to be in the specific form - (@W_Vann_Hall , Thank you!, i am getting there :slightly_smiling_face: )
  5. per law: if someone workes over the midnight, it has to be calculated as two working days, EARNINGS PER DAY!
in a staffing table i have a “test NNJJ” view, where i can export data for daily reports, but how do i do the monthly payroll?
first thught was to have the months summed in the staff table so
  • in a table “staff” i trield to rollout the months and working days, works fine, it rolls out all the monts and all the dates … but how do i filter it “per month”
do i need another table like : if in timetracking table, month = x, then sum working hours? and then do this for every month in every separate collumn?
  • nother thing i dont understand is how to separate two days in the midnight, in a nighshift?
clocking out and in is not an option
sorry, my brain just stopped.
thx!
  • 1386 replies
  • January 9, 2018
First of all,
@Elias_Gomez_Sainz
@W_Vann_Hall
THANK YOU!
Here is a preview:
Rules:
thx!
I’m walking out the door, but I’ll try to get back to you later.
One quick idea, either as monthly calculation, sanity check, budgetary use, whatever: You can quickly arrive at the number of days worked with
LEN(DaysWorkedEncoded)-LEN(SUBSTITUTE(DaysWorkedEncoded,'J','N'))
^---- Note: Suggested formula is incorrect. See next reply.
  • 1386 replies
  • January 24, 2018
First of all,
@Elias_Gomez_Sainz
@W_Vann_Hall
THANK YOU!
Here is a preview:
Rules:
thx!
Well, I see I obviously never walked back in the door. Are you still wrestling with how to extract the information you need? If so, let me know, and I’ll see if I can help…
…and, one hopes, do a better job of helping than I did in my last message, which contained an embarrassingly incorrect formula snippet. The code you need to arrive at the number of days worked would actually be
LEN(DaysWorkedEncoded)-LEN(SUBSTITUTE(DaysWorkedEncoded,'J',''))
The one previously provided would always equate to zero (0).
Alexey_Gusev
Forum|alt.badge.img+23
That’s crazy to answer on topic 7 years ago, but I just found the task interesting, and using ‘formula looping’, quickly crafted it.(reacting on strings like ‘03,06,19,25’ )
So let it be here.
IF(DayIndex, REGEX_REPLACE( REGEX_REPLACE(
 '01N02N03N04N05N06N07N08N09N10N11N12N13N14N15N
 16N17N18N19N20N21N22N23N24N25N26N27N28N29N30N31N',
    '('&SUBSTITUTE(DayIndex,',','N)|(')&')','J'),
'\\d',''))
how cool is that!!!
incredibile to see you found this post!!
a lot has changed since then, but let me trow in some current challange:
legislature text:
“A permanent employment relationship does not exist if, within a calendar quarter, employment takes place within the framework of several fixed-term employment relationships for no more than 40 days at most and there is at least one employment-free period of at least 10 days between two fixed-term employment relationships in the calendar quarter.”
how to pack this into a Formula?
