Attachment names help
  • September 7, 2023
  • 39 views
Hey guys !
I'm using Pabbly to automate a process of generating documents with Airtable.
Thing is Pabbly is creating PDF using Google docs and transferring them to Airtable, which works really fine.
However, in the attachments, while the document has the good title in the viewer, the file name itself is automatically named "UC" without any prefix.
So when I send it by mail, it displays errors, because it sould be "formation - Name.pdf"
Do you know where does it mess ?
Thanks for the help
  • September 14, 2023
Hi Hirokimura,
I'm having the exact same issue, did you find a fix?
Hi Hirokimura,
Hey Ryan_Mate,
So far, I didn't find a direct solution to do it. I have to let the files in the drive folders and put the link in the Airtable base for each file, which is really less convenient than the attached files option. But I'm running out of time and I lost too much time on this process so I cant investigate any further on this 😐
