Best way to handle collaboration
  • April 15, 2021
  • 0 views
Sean_Lake1
Forum|alt.badge.img+20
So our team is semi unique in that some collaborators only need access to certain fields to change, while others need semi admin. The semi admin is easy enough, as I can set them to editors only. But let’s say another set of collaborators, I only share one base, and only want them to be able to edit a certain field or set of fields. Is there a way to do this?
