I have been using the Airtable as ATS, and creating the profile page for our registered customers using the Page Designer feature.
It is possible to edit the layout from Page Designer Edit page, but I don’t see a way to edit the content of the fields directly from Page Designer Edit page.
For editing the content of the fields on the Page Designer, I always have to go back to the record and edit the fields to make changes.
Is there any way to edit the fields directly from Page Designer edit page?
Page 1 / 1
You can’t edit from the Page Designer, but maybe is useful to have split view of the app, gird on the left and blocks on the right, with the PD block as big as possible.
@Kanta_Kiyomoto I have the same issue… the Page Designer app is exactly what I want, except that I want to edit its contents from time to time. Did you (or anybody) find a workaround or other solution?
