🆘 Complicated formula help please
  • Oct 1, 2020 6:12 PM UTC
  • 29 replies
  • 279 views
Show first post
Forum|alt.badge.img+14
  • Oct 7, 2020 5:02 AM UTC
Ok, I just found a little hiccup in the code and am having a tough time finding a solution.
For my “sameShiftRecordsexact” it is pulling in data if the chosen shift is within another shift and not just exactly the same.
I thought this part
    ((triggerValues.start <= x.start && triggerValues.stop >= x.stop)) &&
would just need
instead of
but that didn’t work :frowning: Any help is greatly appreciated :slightly_smiling_face:
Kamille_Parks11
Forum|alt.badge.img+27
I thought this part
would just need
instead of
Did you set both <= and >= to ==?
  • Oct 7, 2020 4:04 PM UTC
Yeah, when I change them both to == it is not recognizing anything for the “sameShiftRecordsExact”.
((triggerValues.start == x.start && triggerValues.stop == x.stop)) &&
  • Oct 7, 2020 10:15 PM UTC
Disregard. I finally figured it out :slightly_smiling_face: Had to change this block of code to with the “toISOString”
Thanks again.
const sameShiftRecordsExact = shiftRecords.filter(x => {
return (x.start.toISOString() == triggerValues.start.toISOString()&&
    (x.stop.toISOString() == triggerValues.stop.toISOString()&&
    (x.location == triggerValues.location))
