Conditional Formatting Column
  • May 28, 2020
  • 40 views
Hello Airtable Community.
I’m actually not sure if the subject is the right for this question but it’s the closest I could think of.
I created a formula field to autofill out instagram.com prior to a profile name to save me re-typing it every time. (Thanks to Scottsworld for helping me with that)
"https://www.instagram.com" & {profilename}
Is there a way to only show instagram.com if a profilename is not empty? ie nothing will show in the formula field if profilename is empty. Hope this makes sense!
Adjust your formula like so: IF({profilename}, "https://www.instagram.com" & {profilename}, "")
Kamille_Parks11
Forum|alt.badge.img+27
  • May 28, 2020
This made me SOOOOO Happy!!! Thank you soooo much!!! I can’t tell you how much this has helped me.
