Conditionally disable buttons based on other field values
  • June 23, 2021
  • 123 views
Hello!
I have a button which is posting Airtable data into a Data Pipeline via a script with a fetch request which returns a success or error via status codes on the fetch response.
This action only needs to happen once so I’d like a way to disable the button when I receive a successful response but I can’t figure out how to do this.
Interestingly I found another topic on here where a button is disabled but I can’t figure out how to replicate this for my use case.
Here is tat topic - Button disabled when lookup field has value
Does anyone know how I might be able to achieve this?
  • June 23, 2021
Buttons that open urls are disabled when the formula for the url produces a blank result.
It currently is not possible to disable a button that calls a script.
  • January 2, 2023
Any update on the above?
