Customising/adding Vega-lite 'examples' to a base
  • February 21, 2023
  • 3 views
Hi folks,
Possibly being a little too ambitious here, but i'm trying to set up a Vega-lite extension to create a geographical heatmap displaying $total sales value per U.S county, using the Vega Editor example 'Choropleth of unemployment rate per County'.
(Originally wanted to go with zip codes, but opted for counties to save creating a 40,000+ record table in my base just to run a single chart).
I'm brand new to vega-lite and json in general, so wondering if anyone has managed to achieve this (or similar)?, or has any general tips in terms of using Vega's Geographical Map Displays in their Airtable Base?
Thanks for reading 🙂
  • February 13, 2025
I am hoping to do the same thing... sounds like no luck getting a response on this. Any chance you figured it out?
