Daily summary from Airtable to Slack
  • July 13, 2020
  • 1 view
I want to get daily summary of records from Airtable to Slack channel. I tried it by Append Entry and Schedule Digest, but it doesn’t work. I also tried instructions from your Airtable blog, but in the Record field I can’t see Use a Custom Value.
Best answer by Zach_Manzi
Hi @Martina_Kudelcikova,
Thanks for posting, and welcome! I believe you’re referring to this article that covers all of the steps to use Zapier to create a daily summary of changes to your base. These instructions are still up-to-date, but there was an interface change that is slightly different than shown in the article. The custom value should still be an option, but it’s now found in a tab up top when selecting the record:
I hope this fixes the issue for you!
  • 9 replies
  • July 24, 2020
