I have a table with an Attachment field holding a PowerPoint PPTX file.
Is there any way (in an Interface or another) I can Drag and drop that file into another (Windows) application? Just adding the file to an Interface doesn't seem to allow drag and drop.
Specifically, I need to drag the file into Canva - Create a Design (Upload).
Best answer by ScottWorld
You would need to download it to your desktop first using the download button. Airtable doesn't support dragging attachments out of Airtable.
