Embedd/display images inside forms
  • September 27, 2020
  • 4 views
I am new to Airtable. Is it possible to display an image/embedded it in Airtable forms? I am not talking about the standard logo/header image. What I would like to do is display images based on if a field was filled or not.
Thanks for a your response in advance :grinning:
Forum|alt.badge.img+15
  • 368 replies
  • September 28, 2020
We built a 3rd-party form for Airtable that supports showing images inside any field. And it also supports conditional fields. So it is possible to achieve what you described.
Thanks for responding @Moe. I saw the video but didn’t see a way to embed consistent or dynamic image. That said, I appreciate what you guys are doing @miniextensions.
  • 368 replies
  • September 29, 2020
The field image feature was added later on. That’s why it’s not included in the video. However, you can see it in the live demo on our website.
