Hi everyone, I'm wanting to improve upon the Extract Base Metadata script to include more features. Has anyone experimented with this?
Ideally it would:
- Gather the metadata currently acquired by the Base Metadata Extract extension (listed below)
 - Be capable of running automatically at regular intervals.
 - Indicate if the field has been deleted.
 - If the field is a linked record field to another table limited to a view, name that view
 - Indicate if the field is in use in an interface
- SHOULD: name those interfaces
 - If the field is a lookup from a linked record, name the originating record
- SHOULD: link directly to that record
 - Show which interfaces the field shows up on and make updates when fields are removed or added to interfaces
