Feature Request: Larger Filter View Area for Data
  • November 21, 2024
  • 2 views
Forum|alt.badge.img+8
When creating filters for views, I often have to select a lot of options from a multiselect field. Once i've selected more than a couple, it becomes difficult to see all my selections.
It would be great if the filter view area could be enlarged to full screen or expand to display all the available options.
MJen
Forum|alt.badge.img+7
  • 11 replies
  • December 28, 2024
I completely get where you’re coming from—working with multiselect filters in a limited view can be frustrating, especially when dealing with a lot of options.
Until the release of this feature, you can try moving your multiselect options into a separate table and linking them back to your primary table. This way, you can filter using linked records, which tend to be more manageable. Or, instead of applying complex filters, try grouping your records by the multiselect field. This will allow to see all the options more clearly and navigate the data without manually scrolling through filter settings.
  • 13 replies
  • December 29, 2024
Thank you Mary for taking the time to offer suggestions. Both are workable solutions and I very well may move the dropdown to a linked table.
