Filter rows by comparing two fields
  • October 15, 2016
  • 111 views
Hi there!
Is there currently a way to filter the rows in a table by comparing two fields?
I’d like to only show rows where a value is not equal to the value of linked record. I am able to display them next to each other using a linked row, but the filter function seems to require a static value to compare with. Am I right on this?
Thanks,
Till
Forum|alt.badge.img+12
  • October 17, 2016
Hi Till,
It’s currently not possible to set this up directly in the Filter menu, but there a simple workaround with one extra step:
  1. First, create a Formula field in the table, with the formula Field1 = Field2, using the names of the two fields you want to compare. To verify that this step was successful, the value should be 1 if the two fields are the same and 0 otherwise.
  2. Filter the table to records where this new Formula field’s value is 1. That will filter it to only records where Field1 and Field2 are the same.
  • November 23, 2016
Hi Till,
Hi Matt, I’m sorry to get back to you so late! I just wanted to thank you for reply, this works perfectly!
  • November 18, 2020
Hi Till,
Nice workaround Matt… worked perfectly!
Forum|alt.badge.img+8
  • July 7, 2021
I have been using the suggested workaround. However, I wish you could specify the field as the comparator without having to add yet another field. Would be a nice feature … just saying.
