Help with IF nest formula
  • December 4, 2018
  • 10 replies
  • 124 views
I am trying to return “Late” when one or several function fields have a date that’s before today AND an attachment field is empty. I have tried the following formula but it’s not working. What am I doing wrong?
AND(
IS_BEFORE(
{Due Date Sponsored Article},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date Sponsored Agenda},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date NL Banners},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date EMail Blast},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”)
AND(
IS_BEFORE(
{Due Date Website Banners},TODAY()),
{Assets}="",
“LATE”,
“Upcoming”))))))
Your formula is not well formatted:
	AND(
		OR(
			Date Check 1,
			Date Check 2,
			Date Check 2,
		{Assets}=""
	'Late',
	'Upcoming'
Change the “Date Checks” to a proper functions, I didn’t want to write all of them :grinning_face_with_smiling_eyes:
  • December 4, 2018
	AND(
		OR(
			Date Check 1,
			Date Check 2,
			Date Check 2,
		{Assets}=""
	'Late',
	'Upcoming'
Thank you Elias, exactly what I needed!
  • December 10, 2018
I might have been too quick to respond actually. There is still something I am doing wrong. Here is the code I am trying:
AND(
OR(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
{Assets}=""
“Late”,
Could it be due to the fact that some of the date fields are empty? If that’s the case, is there a way around?
AND(
OR(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
{Assets}=""
“Late”,
Your {Assets}="" is inside the OR() instead of the AND():
What error are you getting?
Forum|alt.badge.img+14
AND(
OR(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
IS_BEFORE(
{Assets}=""
“Late”,
You are using two different types of quotation mark in that formula. I don’t think the curly ones around the word late are compatible with airtable formulae.
This is often an Apple problem because their keyboards default to using the curly quotation marks.
  • December 10, 2018
Thank you Elias
I am getting Error returned whenever one of the dates is blank (which happens most of the times). When all date fields have a date, it works fine.
Thank you Elias
I think is because of the IS_BEFORE, you can check that. Maybe you have to wrap all of them with IF({Date}, [formula]).
  • December 11, 2018
I am trying to use an IS_Before check date with AND, IF and OR. It’s working but only when all date fields have a date. If a field is blank, it returns ERROR.
Then I tried to wrap each IS_BEFORE check in an IF(). No more errors, but the formula doesn’t return anything at all.
Anyone seeing what I am doing wrong?
AND(
OR(
IF({Due Date Sponsored Article},
IS_BEFORE(
IF({Due Date Sponsored Agenda},
IS_BEFORE(
IF({Due Date NL Banners},
IS_BEFORE(
IF({Due Date EMail Blast},
IS_BEFORE(
IF({Due Date Website Banners},
IS_BEFORE(
{Due Date Website Banners},TODAY())))))),
{Assets}=""
“Late”,
Why you don’t reply to the original post?
You have nested the IFs:
Close them before starting the new one.
  • December 11, 2018
Thanks Elias. I tried that but got the same result (meaning no result).
AND(
OR(
IS_BEFORE(
{Due Date Sponsored Article},TODAY())),
IS_BEFORE(
{Due Date Sponsored Agenda},TODAY())),
IS_BEFORE(
{Due Date NL Banners},TODAY())),
IS_BEFORE(
{Due Date EMail Blast},TODAY())),
IS_BEFORE(
{Due Date Website Banners},TODAY())),
{Assets}=""
“Late”,
