How a collaborator can view only their records
Best answer by Abdullah_Yuksel
Using interfaces will enable you. First create an interface which suits your needs. Then, use the Filter settings that are on the right on the screenshot. You should choose the option "Viewers Record Only". Then choose a collaborator field on the table or an email field. It is ready 🙂
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
