How on earth are people using scripting?
Hi all,
So today I wanted to get a “Mark Duplicate” script up and running on a base. Turns out its one of the featured examples. So I copied the code, adjusted it for my base and hit test and it didn’t work.
The error reporting is rubbish - so I have no idea what went wrong and logging variables doesn’t work.
This is the second time in 3 months I have tried to use the scripts block. I can’t say I am enjoying it, its slow and has no failure message (primitive stack trace)
So my question is - how are others working with this productively. Because at the moment this absolutely sucks and I’d be better off using zaps.
Forum|alt.badge.img+27
  • 6004 replies
  • November 30, 2020
I’m sorry that you are having a difficult time using scripting. You don’t say what your coding background is, so it is difficult to give advice on how to use scripting. It looks like you are using scripting with automations. I recommend starting out using Scripting App. I find testing and debugging much easier in Scripting App. Automation scripts have more moving parts than Scripting App, such as ensuring that you have the proper trigger record when testing.
I personally enjoy using scripting, but it took me writing several scripts and reading a lot of documentation before I became comfortable writing scripts.
  • November 30, 2020
Hey there,
Thanks for getting back to me. I should of said I am a full stack developer with 5ish years in isomorphic js.
Ironically I think this is what makes me less patient with these kinds of tools :rofl:
Ok that’s a good piece of advice of using the scripting app before the automation.
But could you do me a favour and confirm that the “mark duplicates“ example script actually works as a copy paste of in an automation. Because from my perspective it looks broken.
And is there no way to get the line reference that failed. “Test failed” is essentially just a gas lighting system against all devs :slightly_smiling_face:
Sorry two different accounts there. Ones the company “root” account
  • 6004 replies
  • November 30, 2020
Thanks for providing more info on your background. It can be frustrating trying to code in a new environment that doesn’t have all the tools that you are used to using.
The “Mark duplicates” example runs fine for me.
  • 3264 replies
  • November 30, 2020
Dan_Lewis wrote:
Hey there,
Indeed, platforms that attempt to provide development environments often fall well-short of expectations. But, it’s javascript; we have no excuses to overcome these adolescent frameworks. :winking_face:
I typically create an internal logging process that [optionally] stream errors out to another table in the same base using try…catch.
