How to Export images in the same column when exported into CSV and opened in excel?
  • April 23, 2021
  • 31 views
I use airtable primarily to make document product info with pictures in the grid view. It would be great if Iwas able to export the entire view with the pictures in their places in excel. Right now only the image irl is exported in those cells while rest is good. Does anyone have a way to fix this?
  • June 21, 2023
Well, with the app "Excel-Exporter", you can easily do this with the premium version. They have a 7 day free trial if you want to see if it fits you: https://excel-exporter.com/dashboard/app
