Can we PLEASE get a fix for this? I do a lot of data entry in Airtable, and it's very challenging to manage record changes with this setup.
The Problem: If you're working in any grid view with a sort or filter applied, Airtable will often try to sort/filter the record currently being edited, before the entry is completed. If you add any text into a field, every character you add to the record will trigger the re-sort/re-filter, regardless of if you're still actively typing.
Suggestion: It would be ideal if Airtable did not recognize a change to the record until the record is "de-selected" (when the user hits "enter", "tab", clicks away, etc.). It's very frustrating to have a cell I'm actively working on move within the view as I'm doing data entry.
Additionally, this change will reduce processing load in Airtable, because it's not constantly trying to reorganize the data with every keystroke. It would be EVEN BETTER if there was a setting on the view level (in base) or in the interface builder that could turn this functionality on/off if there are specific use cases in which you'd want it to function in this way.
