Hello !
I am trying to achieve item tracking for equipments. The general idea is that items are stored in a location. They will be placed in boxes, which are going to be sent to projects. I would like to get a table of all items with their locations.
I want to be able to scan a barcode on the item, and change its location. That works fine.
Now some boxes always contain the same things, so I want to only scan the box, change its location and that it changes to loation of all the items in the box.
That is almost achieved by linking items to a box, and having a lookup field to get the location of the box. But that is a text field, and not a location field. Is there a way that changing the location of one box will change the location of its items ? -
When putting items in a box, I want to be able to scan them and link them to the box. I know the app on Android does not support modifying fields of type “link to another record”. So I created a single select field with the same box names. After assigning items to a box, copy pasting the box field into the liked field will achieve what I want.
Is there a way that my “linked to” field is automaticaly updated when my “Box” field changes ?
I hope mypost is clear enough !
Thank you.
Robin
