Is there a way to retrieve stock quotes using Airtable?
Is it possible to enter a stock symbol such as AAPL and get the price update as is offered in other spreadsheet programs?
Thanks
Hi Stan,
You can achieve this using ifttt.com stocks triggers and airtable recording.
Let me know if you would like help in setting this up.
Michael
  • May 7, 2017
Michael_Berman wrote:
Hi Stan,
Michael
Hi Michael,
I have read about ifttt but have not tried using it. I searched on google and could not find anything about Airtable using ifttt to retrieve stock prices. If you could offer some hints as to how to do this I would appreciate it.
I would basically like to enter a list of stock symbols and pull their price from Yahoo or Google.
Thanks,
Stan
Ok - I tried to get it to work and it appears not to have that functionality at the moment - I have requested it and if I get a response I will let you know.
  • May 8, 2017
OK Michael, thanks for trying,
Stan
Forum|alt.badge.img+15
  • 368 replies
  • January 13, 2020
We made this tool. It allows you to enter a list of stock symbols in Airtable and it will pull their prices. It can be scheduled to run regularly too.
Forum|alt.badge.img+33
  • 8765 replies
  • May 19, 2020
Hi @Moe, it says in your video that this tool makes an API call to Alpha Vantage once per minute, and that Alpha Vantage only allows a maximum of 500 API requests per day on their free plan. This is true, as I saw on their website here. But if your tool is making an API call once per minute, then after approximately 8.3 hours of running this tool in one day, the free 500 API limit for the day will be reached. So it seems like everyone will need to pay for at least the cheapest pricing plan for Alpha Vantage, which is currently $30 per month. Am I understanding this correctly?
  • 368 replies
  • May 19, 2020
The API limit would only be an issue if you have more than 500 stock and you need to update all stock prices every day. So it depends on how many records (stock symbols) you have. Obviously, this tool is not ideal for updating stock prices in real-time throughout the day (Airtable is not the right platform for this anyway).
  • 8765 replies
  • May 19, 2020
Thanks. Can we limit this tool to not update every 1 minute, but perhaps once an hour?
  • 368 replies
  • May 19, 2020
We don’t support that feature currently. Maybe in the future.
  • 8765 replies
  • September 30, 2020
In Airtable’s Example Script Showcase, there is an Airtable script that is created to retrieve stock quotes from financialmodelingprep.com.
The actual script is located here:
  • 8 replies
  • December 20, 2020
@ScottWorld I may be missing something but I get the prices listed as “undefined.” (See attached.) Have you or anyone else run into this before?
  • 8765 replies
  • December 20, 2020
Not sure. I don’t know Javascript. It’s very possible that the script might be broken. Hopefully, one of the JavaScript experts in the forum can help. Maybe try reaching out to Airtable support, too, since it’s one of their scripts. Their email is support@airtable.com.
  • 8 replies
  • December 21, 2020
Thanks! I sent a note to the team.
  • February 3, 2021
I’ve had the same problem.
I tried an alternative script below, but this actually clears the current price field in my base rather than recording the quote value. If I copy the URL into a browser window, it returns the ticker and price.
Any idea how to capture the price returned from API and update the price field in the base? I’m sure its a notation issue as the URL will return the data in a normal browser window…
let tblStocks = base.getTable(“stk_price”);
let fldTblStocks_symbol = tblStocks.getField(“symbol”);
let fldTblStocks_currentValue = tblStocks.getField(“curr_price”);
let result = await tblStocks.selectRecordsAsync();
for (let record of result.records) {
let stkSymbol = record.getCellValue (fldTblStocks_symbol);
let response = await fetch ('https://financialmodelingprep.com/api/v3/stock/real-time-price/${stkSymbol}?apikey=abcMYKEY123');
let data = await response.json();
if (data) {
    console.log(stkSymbol);
    console.log(data);
   await tblStocks.updateRecordAsync(record, {
       [fldTblStocks_currentValue.id]: data.price
This would be an amazing add-on. Hoping Airtable would want to create something like this.
if (data) {
    console.log(data);
Use the character ` instead of ’ for your fetch statement:
let response = await fetch (`https://financialmodelingprep.com/api/v3/stock/real-time-price/${stkSymbol}?apikey=abcMYKEY123`);
This will allow ${stkSymbol} to be replaced with the actual value.
I created a script to add the current price of a given stock symbol to a specific field. The endpoint it hits is free and doesn’t need any configuration so should be straight forward to use but if not just let me know!
let config = input.config({
    title: 'Current Stock Price Settings',
    description: 'Get the current price of a stock.',
    items: [
        input.config.table('selectedTable', {
            label: 'Table to use',
            description: 'Pick any table in this base!',
        input.config.field('selectedSymbolField', {
            label: 'Field inside the above table where the stock symbol is',
            parentTable: 'selectedTable',
        input.config.field('selectedPriceField', {
            label: 'Field inside the above table where the current price should be shown',
const table = config.selectedTable;
const { records } = await table.selectRecordsAsync({
    fields: [config.selectedSymbolField.name]
const priceField = config.selectedPriceField.name;
let itemsToUpdate = [];
const badStockSymbols = [];
// Loop through all stock symbols, get the price, and create the update objects
await Promise.all(records.map(async (record, index) => {
    // Don't look up empty records
    if (!record.name || record.name === `Unnamed record`) {
        return;
    try {
        const response = await remoteFetchAsync(`https://query1.finance.yahoo.com/v8/finance/chart/${record.name}`);
        const { chart } = await response.json();
        if (chart?.error) {
            badStockSymbols.push(record.name);
            return;
        itemsToUpdate.push({
            fields: {
                [`${priceField}`]: chart?.result[0]?.meta?.regularMarketPrice
        output.clear();
        output.markdown(`Fetched ${(((itemsToUpdate.length + badStockSymbols.length) / records.length) * 100).toFixed(2)}% of stock prices.`);
        return;
    } catch (err) {
        console.log(err);
// Bulk update fields with the current price
while (itemsToUpdate.length > 0) {
    await table.updateRecordsAsync(itemsToUpdate.slice(0, 50));
    itemsToUpdate = itemsToUpdate.slice(50);
output.markdown(`Added stock prices!`);
output.markdown(`Fields with bad symbols. Count: ${badStockSymbols.length}`);
output.table(badStockSymbols);
    items: [
        return;
    try {
        if (chart?.error) {
            return;
            fields: {
        output.clear();
        return;
    } catch (err) {
        console.log(err);
Thanks Derek! Great to get some practical language/functionality around pulling off this integration.
I’m a noob at developing my own extensions, but can hang a little.
I’d like to modify this so it returns the Stock Symbol only from a company name field. Anyone have insights into pulling that off?
Thank you for taking the time to read!
-Mike
  • October 7, 2022
-Mike
Hi Michael! For example, you want it to take a company field that could be google and return GOOGL. Is that correct?
