Long Primary Field
  • January 4, 2018
  • 0 views
I have set my primary field as a long text field, but when I try to print it in gallery view the whole primary field does not print, a portion of it gets cut off.
  • 1386 replies
  • January 4, 2018
According to Airtable’s guide to printing,
For a gallery view, your print options are limited to changing the paper size and layout, but the printed version will retain the gallery card layout.
IIRC, in gallery view, only the first four lines of a long text field are displayed…
