Can anyone point out what i’m doing wrong here?
The goal is to create a list from 30 different fields.
Each field should be on a new line
We want to skip any fields that are empty. E.g don’t add a newline for empty fields.
The latest version of my nested IF formula looks like this. Any help greatly appreciated!
IF ({filename_1}!=BLANK(),filename_1 & “\n”,IF ({filename_2}!=BLANK(),filename_2 & “\n”,IF ({filename_3}!=BLANK(),filename_3 & “\n”,IF ({filename_4}!=BLANK(),filename_4 & “\n”,IF ({filename_5}!=BLANK(),filename_5 & “\n”,IF ({filename_6}!=BLANK(),filename_6 & “\n”,IF ({filename_7}!=BLANK(),filename_7 & “\n”,IF ({filename_8}!=BLANK(),filename_8 & “\n”,IF ({filename_9}!=BLANK(),filename_9 & “\n”,IF ({filename_10}!=BLANK(),filename_10 & “\n”,IF ({filename_11}!=BLANK(),filename_11 & “\n”,IF ({filename_12}!=BLANK(),filename_12 & “\n”,IF ({filename_13}!=BLANK(),filename_13 & “\n”,IF ({filename_14}!=BLANK(),filename_14 & “\n”,IF ({filename_15}!=BLANK(),filename_15 & “\n”,IF ({filename_16}!=BLANK(),filename_16 & “\n”,IF ({filename_17}!=BLANK(),filename_17 & “\n”,IF ({filename_18}!=BLANK(),filename_18 & “\n”,IF ({filename_19}!=BLANK(),filename_19 & “\n”,IF ({filename_20}!=BLANK(),filename_20 & “\n”,IF ({filename_21}!=BLANK(),filename_21 & “\n”,IF ({filename_22}!=BLANK(),filename_22 & “\n”,IF ({filename_23}!=BLANK(),filename_23 & “\n”,IF ({filename_24}!=BLANK(),filename_24 & “\n”,IF ({filename_25}!=BLANK(),filename_25 & “\n”,IF ({filename_26}!=BLANK(),filename_26 & “\n”,IF ({filename_27}!=BLANK(),filename_27 & “\n”,IF ({filename_28}!=BLANK(),filename_28 & “\n”,IF ({filename_29}!=BLANK(),filename_29 & “\n”,IF ({filename_30}!=BLANK(),filename_30 & “\n”))))))))))))))))))))))))))))))
