Nice reporting through layers of relationships
Hello
I have a base structure of:
EVENT → VENUE SLOTS → STAFF ALLOCATIONS
Whee an event can have a number of venue slots (ie each day’s activity) and each slot has a number of staff allocated to it
I would like to be able to produce a report which shows all of the staff that have been allocated to an event, but I can’t see a way to do this. I can only insert a table for children of the master record - I can’t seem to go any deeper?
I was wondering about somehow exporting the data to google sheets but can’t see a great way to do this?
Hi @Richard_Williamson
I assume you are linking all those tables via Linked Record fields?
If so, you can just use a Rollup field in Event table (using ArrayUnique(values)) to get all the names of the Staff
  • 10 replies
  • November 2, 2022
Thanks - the problem though is I would like to be able to get a rollup of all the information (name, start time, finish time, cost) - I suppose I could create a calculated field in the staff_allocations table and report on that but it seems pretty ugly
  • 69 replies
  • November 2, 2022
You need a direct connection between Event and Staff, bypassing Venue.
This way you’ll be able to use Page Designer to list the relationship.
  • 10 replies
  • November 2, 2022
Urgh thanks - I suppose would need to be an automation which updates a field. Airtable is so frustrating how it’s almost great but falls down so badly on the reporting
  • 69 replies
  • November 3, 2022
Yes an automation would do Event 🔗 Staff.
And yes, reporting capabilities are rather poor. That’s why they called it Page Designer and not Report Designer.
