Is there any setting to mess with or extension to install that allows you to have an attachment open, but not fill the entire browser? Unfortunately some of our uploaded attachments are scanned & handwritten PDF forms, but ideally I would like to be able to open the attachment easily in a side panel so I can both view the PDF and still access the grid view of the records and edit a few of the fields. For example, the PDF may have a date on it, name of who prepared the form, and a task all handwritten on it. It is uploaded to the table which creates an essentially empty record that just has an attached PDF and I need info from the PDF to fill out the rest of the record. Side by side would be ideal (some of the handwriting is beyond any type of attempt at image rec).
