'Reconnecting' and 'Saving' Messages
  • September 19, 2024
  • 8 views
Is anyone else constantly interrupted by 'Reconnecting' and/or 'Saving Changes' messages? This happens on some of my least complex bases with a tiny amount of data in them.
It is extremely frustrating, constantly breaks my focus, and causes my work to take longer than it should.
This has been brought up to Airtable many times, but it continues to linger, so I figured I would post here and see if others are facing similar issues.
Hey @brenmcgeown! That never occurred to me, but I'll keep an eye on it.
Hope this gets solved soon.
  • December 11, 2024
This is tormenting me as well.
  • January 11, 2025
Having the same problem....
  • January 29, 2025
Where you able to figure out the issue? And how to fix it?
