Reverse Web Clipper
I am looking for a Chrome extension that sort of acts as a reverse web clipper. The extension should take data from Airtable (or alternatively a csv-file) and put it in certain input fields of a handful of selected websites. I would like to be able to select the input fields via css tags. Does anybody know an extension that would be suitable for the job?
Thanks in advance!
Forum|alt.badge.img+33
  • 8779 replies
  • April 28, 2020
These guys create custom extensions — you may want to ask them:
Request your own custom extension! - miniExtensions
Have an idea that you're trying to achieve, but your technical skill is holding you back? Just contact us and we might build it!
Try "AutoFill Forms" or Zapier’s extension; they map data but have CSS limits. A custom script with PL Web might work better.
