Simple POST Script error 'SyntaxError: Unexpected token C in JSON at position 0,,'
  • July 21, 2021
  • 73 views
I have added a fairly simple scripting block that accesses an endpoint on my application. The error when running this is below, but can’t for the life of me work out what this is referring to.
Has anyone got any ideas?
ERROR
at Unexpected token C in JSON at position 0
let token = await input.textAsync("Insert Token")
let table = base.getTable("test");
let record = await input.recordAsync('Pick a record',table)
let initialRaw = record.getCellValue("updatedcontent")
let recordid = "60cf7b6133fed78cdae3ca48"
let env = await input.buttonsAsync('Choose Environment',
['Test',
'Live'])
var exampleRequest = {
    "items":[
        {"ID":"1234",
        "name":"Mr Smith"};
var exampleRaw = JSON.stringify(exampleRequest)
let raw = JSON.stringify(initialRaw)
let url=''
if (env=='live')
        url= 'https://live.com/user/'+recordid
else
        url='https://test.com/user/'+recordid
console.log(url)
console.log(initialRaw)
console.log(raw)
console.log(exampleRequest)
console.log(exampleRaw)
//POST API LOCATION call
    var myHeaders = new Headers();
    myHeaders.append("Authorization", "Bearer "+token);
    myHeaders.append("Content-Type", "application/json")
    myHeaders.append("Accept", "application/json")
    var requestPostOptions = {
        method: 'POST',
        headers: myHeaders,
        redirect: 'follow',
        body: exampleRaw
    console.log(requestPostOptions)
    let orderResponse = await fetch(url, requestPostOptions);
    let finalResponse = await orderResponse.json()
    console.log(finalResponse)
  • July 21, 2021
When you set exampleRequest you are missing a closing ] and a closing }
    "items":[
        {"ID":"1234",
        "name":"Mr Smith"}
  • July 21, 2021
    "items":[
        {"ID":"1234",
        "name":"Mr Smith"}
Thanks very much, but this error was just part of me trimming the JSON down to an example format.
The syntax error still shows, not sure what it could be?
  • July 22, 2021
The error indicates JSON parsing is failing somewhere. The only place where JSON is being parsed in your example is this line:
Can you check whether the response from your api is valid JSON? E.g. by logging this:
console.log(orderResponse.text());
