[SOLVED] Gantt view/Gantt chart capability
Show first post
  • January 30, 2019
Evaluating AirTable to become the primary CRM, project management, etc. tool enterprise wide for our ~100 employees and growing company… Gantt chart would carry significant weight in our evaluation/decision.
We haven’t fully moved over to Airtable for lack of a Gantt feature. Timeline is useful to a point, but I need to use it with lookup fields and that’s not available. If we could have the Gantt feature as a view (as suggested above) and include lookup fields, that would allow us to let go of our old system and move fully to Airtable.
Agreed, that feature would be so awesome!
Right now, Airtable really doesn’t 2nd as a project managing tool until it can introduce some form of a standard Gantt chart. Smartsheet doesn’t incorporate database functionality, which is a huge bummer, but their Gantt chart is pretty awesome. If Airtable doesn’t develop a Gantt chart from their date fields, it would totally put Smartsheet out of business.
+100 for Gantt charts here at Datactivist
I feel like if the timeline block had an option to set a “depends on” field (so you’d select a field that references other records in the same table), then that would be pretty much sort it…
Kim_Trager1
Ghantt charts would make my life so much easier.
Ditto. Please alert me when you add charts and calendar creation capabilities (need both) and I will sign us up for your service.
Since 2016 this has been a highly requested feature for Airtable to be a serious business project management tool in any enterprise. But no feature exists, not even close. Only pretty little things like “content calendar”. Please, AirTable, launch Gantt or enable some kind of plugin integration.
  • May 18, 2019
Agreed on the above! We need a Gantt view. The timeline block is a very weak feature, with no flexibility of a real Gantt view. It needs to support multiple start and end time cells like the calendar view, and the color coding should support any kind of grouping you can do in the grid view. (Like, by assignee?)
Hi folks! We just launched the Gantt block today. If you have access to Airtable Blocks through the Pro or Enterprise plan, I highly recommend that you go check it out!
This blog post has a good overview of the features included in our Gantt block (including simple drag-and-drop editing, cascading changes, critical path highlighting, grouping, color-coding, and more). For more in-depth guidance, you can check out our support article here, which also has a tutorial video.
If you’re not sure where to start, we just released a bunch of new Gantt-centric templates:
Our Airtable experts will also teach you how to set up a Gantt block and answer all your Gantt questions if you sign up for our live office hours, happening at 9 a.m. PDT on Thursday, May 23. (If you can’t make that time, sign up anyway and we’ll send you a recording later.)
JonathanBowen
For all users interested in Gantt charts - it’s here!
(You need the pro plan to use the Gantt block). Pretty impressed with this on first view. Started by trying to see if I could implement formulas that would drive the dates of all related tasks, but this is built in, so not necessary. :+1:
JB
Nathalie_Collin
Thank You! As a project manager, this is much appreciated. :smiling_face_with_three_hearts: :kissing_heart:
Was waiting for this. Goodbye Trello, goodbye smartsheets. Hello Airtable.
An awesome step forward! Any chance you can add resolution to hours? Not all tasks take a full day and I get dependency errors when I reference to something in the same day…
Michael
  • June 19, 2019
Michael
I am right there with you on this point.
We are a furniture dealership and would like to create a timeline, with milestones, for our projects:
  • Submission date
  • Furniture selected
  • Finishes selected
  • Order Date
  • Install Date (based on lead times from Order Date)
Really, really new to the whole concept of using a program to help manage time/tasks … and I am struggling to get a project overview that works for us …one that shows all the milestone steps, but doesn’t require hours on the back end to set up and maintain :frowning:
Was hoping the Gantt Chart feature would work for us … but it will not track milestones in a single record … looks like we have create ‘linked records’ or ‘linked fields’ or additional tables … and we run about 300 projects through 7 teams, which is a tremendously crazy amount of info to try to manage on multiple records! Projects run through our queue in 1-4 weeks (there are some outliers, but we try to close business quickly!) … so I am looking for ways to increase efficiency, not add more admin tasks to my already super busy teams! :slightly_smiling_face:
So, here is where I sit right now and I am hoping someone with a bit more intelligence about Airtable can assist in getting me where I am trying to go! :slightly_smiling_face:
I have all the dates set as fields … and our projects are set as records … I need a way to show a project timeline, with milestones, in a Gantt type view. Happy to share what I have hammered out on my own … not sure the best way to demonstrate it, so would appreciate a bit of guidance!
  • September 5, 2019
This is really neat. It’s always nice to see such huge leaps in Airtable functionality!
A few enhancements that would make this even more helpful as a scheduling tool (enabling a true replacement to our current Gantt scheduling tool):
  1. Ability to add tasks directly by clicking on the calendar. It is nice to have the ability to drag existing events and create/edit dependencies-- very intuitive. But having to click the plus symbol to add a new record and manually type in start/end dates is a bit cumbersome and unintuitive. Conceivably you could build a bunch of dummy events in a different view and then use the Gantt Block view to edit the durations, dates & dependencies. But being able to create a new event then edit its dates in the Gantt Block would make the process a lot more seamless.
  2. Ability to Skip Weekends / Holidays. This is a nice-to-have feature and a real hurdle when managing Gantt schedules in a business context if you don’t have this. Minimally having a toggle for weekends in the Gantt block settings would go a long way.
Forum|alt.badge.img+10
On top of the request above regarding skipping holidays, PLEASE extend this functionality beyond traditional office M-F schedules and into shifts. The ability to create defined shifts and assign them to the activities like in P6 or Project is 100% crucial for construction use (day shift, swing shift, night shift, long extended weekend work shifts, etc) and the only thing currently holding us back from utilizing this tool.
  • May 20, 2020
  • Submission date
  • Finishes selected
  • Order Date
Hello Geneviene_Lancaster and others,
have you successfully managed using Airtable for Its Gantt functionality and scheduling tool. We are thinking of switching from MS project and smartsheet to Airtable and just wanted to see how Airtable is performing these days when it comes Gantt, dependency and project scheduling?
Thanks
  • May 20, 2020
Matty_Mullins wrote:
Adding gantt functionality in anyway would take airtable to the next level (i.e. convert SmartSheet’s market share) for several reasons.
For Airtable: People who use gantt’s are project and program managers.
Add the Gantt that attracts project and program managers and get exponential sales opportunities with zero time invested for adding leads in a pipeline. They will do your selling.
  • Project Managers typically lead a project which includes a team of people. They have heavy influence on team members and stakeholders, as well as budget to get the project done. This means, if they like a certain tool (e.g. Airtable, Smartsheet, Maven, BaseCamp, etc.), especially if it has a Gantt, they purchase the subscriptions (10-30 people).
  • Program Managers organize and equip a “project of projects” (over simplified), and if they have a tool that can help them predict and coordinate timing, budgets, and quality between project teams (Gantt is a must for this), they will make the purchasing decision for all the projects (30-100 people).
About me: I have over 10 years of program management experience trained at the number 1 school in the nation for this. I’ve applied it from government contracting to starting 2 for-profit and a non-profit successfully on time and on budget for stakeholders (investors and partners). The scopes of our projects reached beyond $100M. I speak with authority on the ROI opportunities this holds for Airtable and for their client’s success. Please feel free to reach out for any questions or followup. M
Hello Matty,
Thanks
Thanks
I apologize for the delay in responding!
I have not found a way to use Airtable to meet our Gantt needs. I am sure there is a way, but I am not a programmer or developer and Airtable does not provide that kind of assistance. So, I am having to figure it out on my own.
The challenge is I see is that the Airtable Gantt block requires each task to be its own record and that is just not feasible with the volume of projects we run.
[c] +1 6786544726 · [o] +1 6787147474x205
Forum|alt.badge.img+20
You could post in the #developers:work-offered category if you would like assistance with a more technical setup. There are lots of people here who could help you.
Thanks, Justin!
Would love the capability to select multiple tasks on the Gantt chart and move/drag them all at the same time. Eg, if we agree on the timeline/sequencing, but want to shift the whole project back a month. This would be a huge timesaver for projects with many tasks.
