[SOLVED] Help With Staging A Base
  • June 14, 2018
  • 27 replies
  • 315 views
Show first post
Forum|alt.badge.img+20
  • September 17, 2018
Hi W_Vann_Hall
Well, I can now say that I finally figured out how to do the De-duplication Routine.
I still have to copy a checkmark, just to kick start it, (it needed a bit of a kick), but once I copied it, the checkmarks are showing in the right places. It seems that I should have linked the records first, then create the Rollup features, with the appropriate formulas. Once I figured that out, it works now. I even took it two steps further, by creating a view showing all records with checkmarks. I also figured out, when I am working on my iPad, if I am just entering a few records, I can copy a checkmark and paste it in the Dupe Check column, instead of filling the column on my Mac. I did these two things all by myself. :grinning: Pretty good, eh!
Thank you for all your help.
MK
P.S. If I can only figure out the formula in the Integromat scenario, that I am working on, then I would be really flying.
MK
  • October 1, 2018
In case it helps, the dedupe block is now live and open to all Pro users. For more info, check out the support article: https://support.airtable.com/hc/en-us/articles/360008332253.
This topic will automatically close tomorrow.
Enjoy!
