[SOLVED] Snapshot recovered, product is has changed
  • February 7, 2018
  • 31 views
All of the data in one of my tables disappeared. I am unsure of why it is missing. I followed the directions to restore a snapshot and that brought my data back.
The one issue I now have is a huge deal breaking problem. The product id field in the restored snapshot has a completely different set of randomly generated numbers from the original table. We are using that number to give each record a unique identifier. This number no longer matches what is on our physical printed labels.
How do I restore the original product id to the restored Snapshot?
  • February 7, 2018
Hi Phil,
Can you check to make sure the records in the original base are not filtered out?
If they were deleted within the past seven days, you may also be able to restore them from the trash.
  • February 7, 2018
Hi Phil,
Beautiful. Restoring from the trash worked perfectly. Thanks!
