Some users edits not saving
Hi all,
A couple of users on my bases are making edits on the base, such as ticking a check box or adding a comment to a record, then when they return to that record the next day their changes have been removed, ie the checkbox is unticked and the comments are gone. This is causing some quite serious issues as we rely on these manual check boxes for quality checking. Anyone come across this issue or have any advice? Thanks.
Forum|alt.badge.img+20
  • 8751 replies
  • June 3, 2024
You can check the activity log of each record to see who or what unchecked the checkboxes (or made other changes to the record). You might have an automation that is unchecking the checkboxes or making other changes.
— ScottWorld, Expert Airtable Consultant
JBJ
  • 36 replies
  • June 3, 2024
Hi @isobelhoward,
@ScottWorld's advice is on point. To check a row's activity, right-clich the row, then click Expand Action, and the right corner you'll have a drop-down menu with an All Activity option (see attached screenshots).
Hope this helps!
JBJ
Airtable Expert
