Star Ratings with Review field
I am looking to make a reviews website, like a business directory with reviews. Is something like this possible in airtable for each listing?
Jelani_Clay
  • December 27, 2022
Not with just Airtable. You can use a 3rd-party form-maker and store the results in Airtable.
Forum|alt.badge.img+27
  • December 27, 2022
It depends on how closely you want your form to look like your screen shot. It is possible to use an Airtable form that gathers all the information you wanted (ratings, text, images, etc.), but Airtable forms always present all inputs in a single column, not a pretty layout like you have.
Forum|alt.badge.img+13
  • January 14, 2025
Our miniExtensions form allows you to display fields side by side for more flexibility regarding the layout of your fields. This way, you would be able to create a form fairly similar to the screenshot you shared without much effort!
